Gearshift assembly
  • #27248
    Garrett Maguire
      Hi there, Garrett here, from Dublin. Hopefully someone can help with thme with this. I have removed the gearshift assembly as I need to replace one of the springs. My problem is, how do I remove the shaft which holds the gear selectors in place. Thanks in advance.
      #27309
      Alain Sauvage
        Hi I recently took the gear selector appart on my 1955 car, on page 170 parts manual there is a hole in the ball piece 500628, the parts manual shows this labelled 1067 where a round headed pin that goes through this about 4 cm long and flattened off to retain in place. With a small file I filled down the edges of the flattened portion and rotated it to do this. Then it can be pulled out and it all comes to pieces.
