Inlet manifold
Traction Owner’s Club Forums Technical Engine Inlet manifold
  • This topic has 3 replies, 3 voices, and was last updated 5 months ago by Chris.
  • #37279
    John White
      Inlet manifold drain
      #37281
      Robert Filbey
        John you might want to provide a little bit more context with your post.  Are you looking for this part?
        #37283
        John White
          Apologies folks.
          Got side tracked just as about to type!
          Recently had a rough running engine but have eventually hopefully tracked down the problem.
          Never had the original inlet manifold drain tube but just a bolt screwed in to it.Turns out this had slackened off and I can only assume was drawing too much air. However was a good opportunity to drill a half mm hole through the bolt  and loctite the bolt back in.
          Also gave the Solex a strip down and all appears good again.
          #37315
            Sounds good John!
            I think the intent of the tube is to ensure that any fuel dribbling out drops safely past the exhaust manifold.
            But it’s the fumes that ignite, not the liquid so I don’t think it’s a big deal.
