Interior trim
  • This topic has 5 replies, 3 voices, and was last updated 5 years ago by Non Member.
  • #27932
    Non Member
      Hi – does anyone have any pictures of, or advice about,  the covering – if any – that should be over the rear wheel arches where they protrude into the cabin either side of the rear bench seat on my 1952 Traction Avant? Many thanks, Steve
      #27933
      Nigel Watling
        20200721_191615DSC_1177
        Hello Stephen
        I covered mine with a sound deadening foil then covered this with vinyl, on hind sight I should have used a layer of thin foam under the vinyl so as to hide some of the ribs and blemishes in the steel.
        I may still add a layer of foam and then another layer of vinyl covering to improve the look.
        Nigel
        #27934
        Alistair
          I lined my arches with scrim foam (2-3mm) followed by the vinyl. My thought behind it was to give it a slight cushioning!
          Alistair
          #27940
          Non Member
            Thanks so much for your advice, Nigel & Alistair. Does anyone know what the original materials were?
            Steve
            #27941
            Alistair
              As far as I know rexine was used post war….a type of faux leather.
              Prior to doing my ‘53 Light 15 the original rexine was glued directly onto the wheel arches with a hessian material giving some padding. The  squab and seat back rest was all leather and the seat backs(rear) were rexine.
              My prewar 12 was all leather.
              Alistair
              #27944
              Non Member
                Many thanks, Alistair
