Traction Owner’s Club › Forums › Forum Archive › Traction Owners Club Forum › Help Wanted › Leaking Water Pump
@bazessex wrote:
Of course you could go electric………………………..
Electric water pump?
I think it is more the fact that Citroen designed a water pump that was outside the motor and hence prone to leaking. I suppose when they were new and not pitted from rust attack they worked fine. But what is the purpose of the open axle and even more, the big hole that lets the water run all over the clutch 😯
TA was originally designed to be fitted with an auto gearbox so no clutch… However Citroen couldn’t get it to stop overheating and ‘cobbled’ together the manual gearbox and linkage and just never went back to the original planned setup.
@NormanAnderson wrote:
Ian, thanks for the heads up. Was just about to send my water pump off to CAS. I won’t now!
Perhaps the best place to send it will be to Chris at the TOC club shop after all.
Hi Norman
They are sending me another one. They say that they are tested for 24 hours, but I suppose a leak will only get through once the oil has disappeared. I will hopefully get this swapped out next week and will be able to tell you if it is OK.
I am sure most of the pumps are from the same refurb factory anyway.
Ian
Yes electric water pump. I have one on my MGF. I hope the replacement works.
Ian
Thanks Ian, I’m a long way off water pumps anyway, so it can wait. The old pump is just sitting on the bench staring at me…
Borrowed a car trailer for Wednesday next week when I will ship the sorry mess to Mark the welder to weave his magic. Hopefully it will start to look more like a car and less like a bucket of rust. I might even start to like the thing…
New pump arrived – will get on and fit it and see what happens
Good luck Ian. Hope this one finally does the job.
Ian
If you ever need any help or just someone to moan at give me a shout and I will come and help. I have my own to do but having bought rust bucket MGs in the past I know how disheartening it can be.
New pump in and so far no obvious leaks (except for my inlet pipe that is getting rather worn after so many water pump installations 🙁
Need to give the engine a good thrashing to test it but first need to sort out my rear engine mount and that “booming” noise (see my other thread on this)
That’s very kind of you, much appreciated. I need all the help and advice I can get!
Test run done at all speeds (due to speedo going faulty, using GPS) – nice 125 kph on the flat.
And no leaks at all. First time I have not had a leak from the water pump since doing the car. 😀 😀
Job Done!!
Glad to hear that it is all working fine.
