Leather Rear Door Pull Handles
Traction Owner’s Club Forums Technical Bodywork & interior Leather Rear Door Pull Handles
  • #27678
    Nigel Watling
      Could anybody post some pictures and measurements of the rear door pull handles as fitted to the Slough Light 15, mine are missing and can’t find anything on the net to make a copy from, any help would be appreciated.
      Many  thanks
      Nigel
      #27679
      David Selfridge
        Hi Nigel, The drill holes at the top of one of doors became elongated, which meant the door card clips would not hold the door cards in place, leaving a small gap. I fitted door pull straps (Morris Minor) which I had in stock, my leather upholsterer fitted new matching leather, with leather scraps left over from my interior restoration. I still have a few Minor pull straps left over. If  you could get them fitted with your own colour matching leather (currently light blue colour) I would be happy to send them to you FOC. Photo of similar EBay.
        Davy317F67AA-DDF9-43D7-877D-E23898212340
        #27680
        Nigel Watling
          Door Card
          Hello David
          That’s a fantastic offer but as can be seen from my picture the mounting screws on mine are vertical or do the straps you show mount horizontally?
          There is no reason I couldn’t drill another hole and mount them to hang vertically.
          Your thoughts and any chance of a picture of yours please for reference.
          Nigel
          #27682
          David Selfridge
            Hi Nigel, The problems with the Minor straps would be if you drilled another hole,  it would expose the existing hole beside the strap. Do you have straps on the front doors?, you would want 972FE436-BFFA-498B-B26E-C1303834C2F7AB8AE947-148A-45ED-90D9-C0A381BA53D49AE78ECF-5311-41F1-9BBA-9143BB332558them to match, front & back
            I fitted my straps before any holes were drilled in the leather.
            #27686
            Nigel Watling
              Hi David
              No my front doors don’t have straps and there no holes in steel work to say there ever was, albeit my car is Slough built my door panels and front seats are vinyl and no decorative stitching as per your pictures but have the wood panel so good chance mine  are not originals, but on saying that the variations seems endless, what ever was available at the time I suppose. Thinking on your comments about spare screw hole I have decided to make mine using the two vertical screws I have and form a steel cover over the top section. I’ll post follow up picture when fitted.
              Nigel
              • This reply was modified 5 years, 4 months ago by Nigel Watling.
              • This reply was modified 5 years, 4 months ago by Nigel Watling. Reason: spell
              #27694
              David Selfridge
                Hi Nigel, Hope everything goes well, fitting your leather door pulls. Please post pictures of your final modification, should turn out fine.
                My car is a 1938 Slough Traction Avant “Twelve” the raised swan necks and side pockets are as per original door cards, and the narrow stitching panels in the seats where copied from the original. 3285BE9B-7BFC-4510-9582-CCB31942608E012624D3-1A97-4171-9069-D72CA6ADF0BCA5330847-45B7-4EAC-BC61-42F411914A75
                Davy
                #27814
                Nigel Watling
                  door pull
                  Hi David
                  This is what I came up with as end results, should have wiped finger prints off before taking picture.
                  Nigel
                  #27815
                  David Selfridge
                    Hi Nigel,
                    You should be Well Pleased with the result, looks very good indeed.
                    Davy
