New transfer for '53 Slough Instrument cluster
Traction Owner’s Club › Forums › Technical › Bodywork & interior › New transfer for '53 Slough Instrument cluster
  • #25209
    Norman Anderson
      Hi Folks, I know that the TOC Shop does a transfer for the speedo, but any ideas on replacing this for my ’53 Slough Light 15? The sun has crazed and yellowed the original perspex.
      802XUD_Lo_Res61
      Thanks, Norman
      #25217
        Hi Norman
        I imagine the perspex needs replacing and can’t be polished back to being clear.
        In an earlier time I suspect you could have found some reverse-printed Letraset that you could transfer onto the back of a new piece of perspex.
        Assuming there’s nothing like that available on ebay you could scan your existing dial and print your own transfer using this wet transfer paper …http://lazertran.com
        Seems like a good way to while away a few hours.
        Norman Anderson
          Thanks Chris,
          Just got this from Josh Lockwood. Wonder if TOC Spares would like to join me to get some in stock and bring the costs down?
          Hello Norman,
          This is something we can replicate if you send us the original for reference and accuracy.
          However, there’s a minimum setup fee for a new dial/production run as we manufacture in batches. This means the unit cost is dramatically lower if multiple of the same dial are ordered since the fees are distributed among them.
          The pricing for this is as follows:
          1x = £150 + VAT each
          5x = £55 + VAT each
          10x = £40 + VAT each
          Further discounts apply to quantities in excess of this.
          Kind regards,
          Josh
          Lockwood
          #25221
            Thanks Norman,
            Interesting.
            I’ll ask Chris T and John M (Slough Champion) to consider and recommend.
            Roger Grix
              Hi,
              Transfers were available from Spares a short while ago. Have you asked Chris Treagust?
              If he does not have stock, I may be able to help you as I redid mine twice. The first attempt was a little out of line but for most people would probably be acceptable.
              Roger
              #25231
              Norman Anderson
                Hi Roger and Chris, thanks for the info.
                For some reason, I thought Chris only had speedo transfers. This is not the case. He tells me that they have transfers for this instrument. I’ve asked for one, but haven’t heard back from him yet.
                Thanks again, Norman
                #25242
                Roger Grix
                  Hi Norman
                  A word of warning. The transfers that I got were incorrect. The notch for lining up with the notch in the perspex so that the dial sits correctly in the case was incorrect. Not a problem as long as you know before you stick on the transfer. I had to cut a new notch in the perspex so that the dial was in the correct position.
                  Before you start, sit the new transfer on your old dial and see if the notch is in the correct position. If not, mark the correct position and use your mark when fitting the transfer, ignoring the other one.
                  This problem may have been sorted out but worth a check before you start.
                  Regards,
                  Roger
                  #25247
                  Norman Anderson
                    Thanks Roger, will be careful!
                    Do you know if the club supply the perspex as well?
                    #25250
                    Roger Grix
                      Hi Norman,
                      Yes, the decal comes with the perspex and instructions. It does not come with the rubber sealing ring or glass.
                      If you have any queries when you get all the bits together, contact me and we can discuss it.
                      Roger
