The oil filler cap on the Perfo rocker box with its spring clips seems to be designed to drop the oil vapour that collects on its underside onto the rocker box.
It then runs down into the specially designed gutter where it sits until it is full enough to run down the engine.
I thought that I would fix it and installed some U channel “rubber” around the rim of the filler and re-fitted the cap.
It seemed to work but then I started to worry that I might be stopping any water vapour in the engine from escaping. (Not sure if there should be any water vapour – probably not but if there is – better out than in.)
I also wondered whether there might be a slight pressurisation in the rocker box and what that might do.
Any comments?
Roger
