Removal of inner bearing – Driveshaft
Traction Owner’s Club Forums Forum Archive Traction Owners Club Forum Help Wanted Removal of inner bearing – Driveshaft
  • #4267
      Hi
      I am at another sticking point. Has anyone removed the inner bearing in the hub on the stub axle. I have everything off except I cannot work out or with force, get the hub and inner bearing off the stub axle. I know there is yet another special tool but I am sure I heard that it was not necessary for this particular job.
      Any hints or tips ❓ ❓
      [attachment=0:3uex2otx]P1060659.jpg[/attachment:3uex2otx]
      #5521
        No worries, I had a cup of tea and a think and went back out to the garage and got my blow torch and a bigger hammer. Both came off without to much bother.
        But what is the best method of putting the new bearings back in. I plan to install the hubs onto the front suspension with the inner bearing installed. Then I assume I will push the stub axle through and then using the nut, screw it on pulling the stub axle into the inner bearing.
        Is that right, or am I missing something.
        Now for lots more cleaning…. 😀
        #5522
          You’re not missing anything- you can knock the new bearing into the hub with a block of wood, then the shaft goes into it and is tightened by the bearing ring nut. Easy with the right tools. If you have a shielded bearing and sometimes they come that way, you can pop out the shield on the side that faces outboard with a small screwdriver so the bearing gets the proper grease load. The inboard facing shield can stay.
          #5523
            Cheers – I bought the sealed units from CAS so hoping they are maintenance free other than the normal grease going in.
            I put them in the hubs and now just waiting for the rubbers gaiters to arrive so I can start mounting everything back on the car.
