Replacing differential oil seals
Traction Owner’s Club Forums Forum Archive Traction Owners Club Forum Help Wanted Replacing differential oil seals
  • #4239
      I am about to fit new cv drive shafts to my 1955 Familiale and want to replace the oil seals on the differential as an annoying leak from the gearbox has developed. I was hoping to do this when shafts were out but with gearbox still in situ. Does anyone know if this is possible and, if it has been done, can any advice be offered? Gearbox removal might be a little beyond my limited skill/workshop facilities! Thanks in advance.
      #5376
        You really need to remove the box to do this properly as the bell housing should be taken off. You may be able to loosen the bolts with the box in place but then, you will have to deal with sealing the gearbox to the bell housing. You can remove the flange yokes from the gearbox and look at the area where the seal rides. If there is a groove worn into it, you can have the groove welded up and machined for a smooth surface. I’ve done this and it does work but best with new seals.
        It’s really best to pull the engine and do it right. Take off the radiator and cross beam, disconnect the shift rods, throttle links, exhaust, etc. Since you’ve got the shafts out, it’s easy. A smooth floor (essential) an engine hoist and a chain around the water pump and you’re all set. Plus, if you pull off the bell housing you can clean out the old gunk that will be in the gearbox. Really, with a wide bodied car like that, it’s not difficult.
        #5377
          Thanks for advice. Sounds like a job for Winter!
