Speedo connection
  • #28400
    Carl Fuss
      Hi
      we have a Slough built 1952 light 15, all running well, touch wood , and ready for the National Weekend. We’ve had a few problems with the speedo going on and off, a jiggle about with the connection at the gear box seemed to help but now its off all the time. Just wondering where to look for the possible cause.
      Carl
      #28401
        Carl,
        If the cable is securely attached at the gearbox end the problem is probably not there.
        Have you checked the cable connection at the back of the speedo?  It is a finger nut and, if loose, could cause the speedo to cut in and out as the square end of the inner cable  becomes disengaged from the drive hole.
        As it sometimes works the inner cable is unlikely to be broken but it is still worth checking.  Probably wortb stripping the cable out, cleaning and re-greasing while you are at it.
        B……
        #28408
        Carl Fuss
          Thanks for the prompt reply, I’ll check it out this weekend
          Carl
