Temperature and oil pressure gauge
Traction Owner’s Club › Forums › Technical › Other › Temperature and oil pressure gauge
  • This topic has 3 replies, 2 voices, and was last updated 2 years ago by Chris.
  • #36551
    Dave Thornley
      Finally decided to fit temperature and oil pressure gauge to the old girl. As usual I do not want to take the easy course as in putting two gauges onto a bracket and attaching to bottom of dash. Oh no I have decided to use a single dual gauge, as fitted to some MGB GT V8s. The main attraction is that I can get one in magnolia which will blend in very nicely with the fascia.
      I have attached a drawing of dash with my possible positions.
      A is the easiest after removal of position swich that is defunct anyway.
      B and C present problems due to associated metal work behind there hence my favouring A.
      I do now want to start cutting holes for B or C and then find not suitable.
      The cutout has to be 52mm
      #36555
        I’d vote for A for the same reasons you state.
        But, if you don’t want to cut the dash board you could get a thing that displays on your phone.
        #36557
        Dave Thornley
          I will stick with the gauge as phones and me often do not get on. I think it should look nice once installed. Gauge is on order so then I have the fun of connecting it up. Oil pressure is decided but as to water temp still to decide whether to remove water pump and drill that or fit one of the inline hose gizmos from ali express.
          • This reply was modified 2 years ago by Dave Thornley.
          #36563
            Nice looking dial – I look forward to seeing how it all goes together.
