Thrust bearing sticking
Traction Owner’s Club Forums Technical Gearbox & drive shafts Thrust bearing sticking
Viewing 1 post (of 1 total)
  • #24636
    Non Member
      The clutch has failed on my 55 11BL perfo. I have taken the gearbox off and some of the pressure plate fingers are damaged.When the clutch leaver is puled the release bearing carrier is sticking, in the engaged position, on the gearbox shaft. A little twist and it snaps back. The little spring is and the gear box springs are Ok. The problem seems to be a little play in the fit between the  carrier causing it to lock up. Is this a problem? or will it the carrier sit square once the box is back in place? I am reluctant to refit the box until I have cured this problem. Thanks all
