Trim washers
  • This topic has 9 replies, 5 voices, and was last updated 6 years ago by Philip Smith.
  • #26350
    Norman Anderson
      Greetings collective isolators,
      I’ve scoured the Internet and usual suppliers for these countersunk washers. They are used to secure the door window trims, rear window trim and windscreen trim.
      any ideas as to where they can be sourced? Should be brass or brass plate me thinks.
      8B7385F1-0745-445C-A287-0EF3BF5FE415
      #26353
        Norman, try searching for “cup washers ” on Google
        B…….
        #26354
        Jonathan
          Woolies do a range but much larger range from LAS Aerospace in Okehampton. (Not sure if either are working during this house arrest though!)
          #26355
          Norman Anderson
            Hi Bernie, thanks for that. Only problem is they are not cup washers.
            cup washers are designed to accommodate countersink screws on a flat surface. The holes in the frames are in fact countersunk already, so cup washers wouldn’t work.
            C44C8C77-3176-401B-8A4C-C63B88133F2F
            #26356
            Norman Anderson
              Perfect, thanks #1177!
              Here they are!21FA2645-E7B6-46D0-9CE2-0049675B9149
              #26359
              Jonathan
                Norman, glad to be of help.
                Im sorry, I don’t mean to be anonymous but screwed up when initially logging in and haven’t worked out how to change it! (Technophobe!)
                cheers
                Jonathan
                #26361
                  Jonathan,
                  Click on your “name”/picture in one of your posts to reveal your profile.
                  Click on  “Edit” at foot of list.
                  You may need to confirm your  ID then you will be able to change your name in the “Display Name” box.
                  B……
                  #26366
                  Jonathan
                    Thanks Bernie – easy when you know how!
                    stay safe
                    J
                    #26367
                      You can find what you need here: http://www.restorationspecialties.com/Washers_c_301.html
                      They are in the States and are very good to deal with; they will sell you the exact amount of whatever you need. And they have everything!
                      #26398
                      Philip Smith
                        Woolies do them they are called dished cup washers on their site.
                        I got some from them a few weeks ago and they are perfect.
                        You need size 6
                        https://www.woolies-trim.co.uk/category/339/cup-washers
                        • This reply was modified 6 years ago by Philip Smith.
