What Carburettor
Traction Owner’s Club Forums Technical Engine What Carburettor
  • This topic has 15 replies, 7 voices, and was last updated 6 years ago by Martin de Little.
Viewing 15 posts - 1 through 15 (of 16 total)
  • #25385
      Hi Everyone
      I have a 1939 French Built 11BL and I now need a new carburettor, I want to make sure that I purchase the correct one, I have 3 alternative  Solex carbs listed, can anyone help with finding out which one is correct. I have the long cylindrical air cleaner
      contact mobile 07802 190677 home 01372 454822
      thanks Alan
      #25401
        Alan,
        The carb on your car is a 35FAIE.  This is the model shown in the illustrations on plate 21 in the workshop manual.   That reference is probably marked at the top on one side.
        It has a 2-part body and the top is tapped to accept the two fixing screws for the air cleaner/silencer “frog” connector.
        B………………
        #25402
          Hi
          A bit of an update thank you for the information, the traction is going well but the carburettor has excessive wear in the butterfly spindle and the car will not idle. As you say the Traction is fitted with a Solex 35 FAIE . What does the “E” stand for, I have seen Solex 35FAI for sale? Frassens list the correct carb as being a Solex 35 FPAI another option may be Solex 35FATIP but that I think it is an outside chance any information would be a help and information on carbs for sale also
          regards
          Alan
          #25405
            Alan you could get it professionally rebuilt including the spindle rebushed etc. somewhere like the Carburettor Hospital http://www.carburettorspecialists.com/  others may be available 🙂
            To help the search it’s listed as fitted to some other cars as well so you could try the individual mark clubs for more info/repair kits:
            Solex 35FAIE; 35RFAIE
            As fitted to:
            Bedford WD: OW, OX, OY, OXA, OXD, OXC 1940-1947 35RFAIE
            Bedford QL3 FWD 1940-1947 35RFAIE
            Citroen Light 15 1946-49 35FAIE
            Morris Commercial 5 Ton 4 Cyl 1945-53 35FAIE
            Shelvoke & Drewry Freighter 3.6 Litre 1947-1952 35RFAIE
            Shelvoke & Drewry Fork Lift 1952-1967 35RFAIE
            Standard 14HP Sedan 1946-48 35FAIE
            Triumph  18TR Roadster 1946-1949 35FAIE
            Triumph 18T Saloon 1947-1949 35FAIE
            EDIT: there is a French discussion online Here: http://forumgmt.fr/viewtopic.php?id=9907 if you open in Google then right click translate to English if your French is like mine it does say in 1 post “Nota Bene: Ma 11B 1939 is equipped with a carburetor Solex 35 FATIP. (But he still misses to this day, the intake muffler ref 480342 type bazooka)”
            Good luck with the research.
            • This reply was modified 6 years, 4 months ago by David Faulkner. Reason: Added link
            #25407
              Hi David
              Thank You for the information could you let me know what vehicles the Solex 30FPAI was fitted to as I think that is the correct one but I have the “bazooka” type air filter, It does get complicated
              Thanks
              Alan
              #25408
                Apparently this place (Carburetter Exchange) in Leighton Buzzard is run by an ex-Solex employee
                http://www.carbex.demon.co.uk/index.html
                Solex were taken over by Zenith – and Burlen supply parts for Zeniths and Solex. http://www.zenithcarb.co.uk
                Either of those could probably break the code.
                  I think the T in FATIP means it has a temperature controlled choke.
                    You could be right Chris, James Geddes had a pre war Normale in his workshop (Traction Repairs) and that had a Solex fitted with a temperature controlled choke.  He might have a picture of it Alan if you contact him.
                    #25417
                      Folks,
                      I have unearthed the following table explaining the letter codes for Solex Carb Identifications:
                      A –          Bi-Starter (Manually Operated)                                 IH –         Semi-Down Draught Carb. 45o
                      AT –        Progressive Thermostarter (Combination of         N –          Non-Spillable
                      Manually and Thermally Operated)                          O –        Zero Starter (Manually Operated)
                      B –          B Type Carburettor                                                       OS          Offset 0o F Strangler
                      C –          Monobloc        P –          Pump
                      D –          Right Hand Carburettor                                               R –          Governor
                      E –          Economy Device                                                            S –           Self Starter
                      F –           Die Cast        T –          Thermostarter (Thermally Operated)
                      G –          Left Hand Carburettor                                                 V –          Vertical Carburettor
                      H –          Horizontal Carburettor                                                W –         Waterproof
                      I –           Down-Draught Carburettor                                        X –          Gas Carburettor
                      L –           Bronze Carburettor or Bronze Throttle Body        Z –          Dust Proof
                      B………….
                      #25427
                      Alistair
                        The members section has all this under the Solex Instruction manual booklet.
                        Does anyone look at these pages??
                        Happy tuning!
                        Alistair
                        #25428
                          I do – That is where I got it from!
                          B……….
                          #25429
                          Alistair
                            That’s two people then!!
                            #25433
                              Yes, but what is a “B” type carb? What does it refer to?
                              #25434
                              Alistair
                                Maybe a dual port carb as opposed to a simple carb?? Just a thought.
                                #25436
                                  I don’t think so- our later Tractions have a 32PBIC, Pump, B type, Downdraft, Monobloc. I assume P means the accelerator pump. But “B type” doesn’t tell me anything. My 1960 Saab has a similar carb but without an accelerator pump called a 40AI. No P designation- its’ similar to the 32PBIC but with a blank plate where the pump would be.
