Wheels
  • This topic has 9 replies, 2 voices, and was last updated 4 years ago by Bernie.
  • #29286
    Ian Wilson
      Hi, My first post on the forum,  I would like to get a couple of spare wheels, to refurb, can anyone tell me where I might locate some.
      Thanks Ian
      #29288
        Ian,
        Slough or Paris? Standard or specials?
        if you are not sure, I suggest you add a photo
        Good luck.
        B…….
        #29290
        Ian Wilson
          Hi Bernie,  Paris built standard.
          Cheers Ian
          #29291
            Ian,
            That should make life a little easier – presumably 185×400 as you are in the 6 cylinder section of the forum.
            I  can’t help you myself at the moment but if you are still looking next summer I can almost certainly pick some up from one of my French  friends.
            Meanwhile, have you tried Bryn Hughes? He has an ad in the classifieds in recent issues of FP and I know he has some interesting stuff.
            Keep us posted.
            B…
            #29292
            Ian Wilson
              Ops sorry everyone, I don’t have a big 6, but a 52 11BL. must get some new specs ..
              Ian
              #29297
                Ian,
                I have found I do have a couple of French 165×400 rims left over from my 4-cylinder days.
                I am located in Wellingborough, Northants – not exactly on your doorstep but a bit nearer than Bryn whom I suggested earlier.
                Let me know if you are still looking and I shall take some pictures for you.
                I also have a number of part worn tyres which will be well past their “best by” date as far as road use is concerned but ideal for a car in store when lack of regular driving can result in a set in the tyres.
                #29298
                Ian Wilson
                  Hi, yes that would be great thanks, I am ok for part worn tyres.
                  Ian
                  #29299
                    Ian,
                    Du to my current “indisposition” I shall need help to move bits so it will take a couple of days.
                    I shall send direct go your personal email  (I assume the one with the motorcycle reference is OK).
                    #29300
                    Ian Wilson
                      Hi Bernie,  yes please, to that email would be a Triumph 😉
                      #29306
                        Ian,
                        Pictures sent …. but one wheel only.  It transpires the other is a Slough rim.  Sorry.
                        I did a lot of “front-end” work and found a Slough rim and tyre as good as (if not better than) the various designs of hub-locking tools when undoing the main driveshaft nuts. Having a large clear hole in the centre, those nuts could be accessed with the wheel fitted and chocked and thus using the weight of the car to prevent the hub turning.
                        B………
