Tim,
The trim has a couple of lugs with screws into the body shell and requires a little – or more – judicial persuading to free it, but ……….
If you only want to get the motor out without disturbing the linkages to the wipers, you should be able to access it via the hole in the firewall behind the battery box. You will need to remove bonnet and battery, of course.
B……
