Reply To: Removal of 6v under-dash wiper motor
Traction Owner’s Club › Forums › Technical › Electrics › Removal of 6v under-dash wiper motor › Reply To: Removal of 6v under-dash wiper motor
#22703
Peter Fereday
    This is probably the most difficult job to access on a French built traction!
    The topic has come up before – see https://traction-owners.co.uk/forums/topic/wiper-motor-gearing-problem/
    Basically if you remove the glove box – screws inside it, and the battery followed by bulkhead panel behind, you should be able to see and access the wiper motor. There is no need to remove the mechanism, the motor can be removed separately.
    A new motor should be available from club spares, but you could ask Chris if he has any working second hand units – some were purchased from Andy Burnett at the end of last year.
    Good luck
    Peter Fereday
