Reply To: Window frames
Traction Owner’s Club › Forums › Technical › Bodywork & interior › Window frames › Reply To: Window frames
#24257
    Norman,
    Depending on your success with JG …
    1) – The windscreen frame of a Light 15 is part no. 221217 which appears to be the same as that of a pre-’52 Légère so I do not believe you will have too much difficulty in locating one should you need to.  I have contacts in France for second hand bits if required.
    2) – I can confirm I do have a UK contact capable of “scumbling” should you need it.
    B…………
