#24513
    Roger, that’s what we suspect as well adding in the effects of the badly corroded water tube but the difference between the old and new valves is even visually quite different.
    water_tubenew_v_old_valve
    Chris, my neighbour had a 6 cylinder BMW that had 1 bent con rod, suspected cause water ingestion, as water doesn’t compress, the con rod bent…
