Reply To: Carb fuel inlet
Traction Owner’s Club › Forums › Technical › Engine › Carb fuel inlet › Reply To: Carb fuel inlet
#25146
Norman Anderson
    Site logged me out after I hit submit, so lost the post.
    Only run the engine up to temperature a few times, so don’t know how the exhaust manifold will behave, but will let you know once I finally get it on the road!
    I’m still struggling with the exhaust fitment. I’ve only got two ‘hangars’ – one at the end of the long straight piece, just in front of the rear wheel arch, and one to support the tail pipe. It doesn’t seem enough. I can see two old straps in the cavity forward of the fuel tank. For the suspension maybe? The parts diagram only shows the two suspension points. Confusing!
    Justin ,apologies for the thread creep. You can have the carb by way of compenstaion!
