Reply To: Have I ruined my battery?
Traction Owner’s Club › Forums › Technical › Electrics › Have I ruined my battery? › Reply To: Have I ruined my battery?
#25216
    Hi Julian – you’ve probably got away with it.
    Load testing a battery is not easy and needs special gear – but if it starts the engine it should be ok on that score – especially being a 6V battery. Seeing if it holds charge just need time to see if it discharges.
    Charging a battery needs higher voltage than the battery says on the label so they are tolerant of some over voltage.
    Other opinions may vary!
