Traction Owner’s Club › Forums › Technical › Engine › Carb fuel inlet › Reply To: Carb fuel inlet
Justin,
I see this problem quite often. Clean up the brass pipe and the bore of the aluminium casting and glue it in there with Loctite 243. You could use a stronger grade if you wanted.
Mark
