Reply To: Window Channels
Traction Owner’s Club › Forums › Technical › Bodywork & interior › Window Channels › Reply To: Window Channels
#25857
    Chris,
    Sorry, no pictures but ……..
    The clips need to align with relevant slots in the door frame.  I suggest initially fitting the channel without the clips then placing chalk marks in line with the slots to assure correct location of the clips.
    You can then remove the channel and fit the clips.   With the long “tail” of the clip pointing to the outside of the channel when it is fitted to the vehicle, push the two tangs through the bottom of the “U” section of the channel from the outside and fold them over inside to secure them.  You may need to punch suitable slots through the trim first with a flat-blade screwdriver or similar because the channel can be quite easily damaged.
    When fitting the channel, the tails of the clips should all fit into a slot and the two loose ends should each be secured in the steel side guides in the door by a steel tag which must be bent to fit into and retain the channel.  If these tags are damaged or missing (not uncommon) – or if the channel has been cut too short to give a tight fit – I recommend using an adhesive to ensure the ends are located and secured.  This should minimises the risk of the channel being dragged down by the glass.
    B.………..
