Hi Norman,
You look to have a post ’53 Light 15.
The L15 2 spoke steering wheel is different from the French one. I don’t know if the mounting is the same. Mine (’55 Light 15) was fitted with an older 3 spoke wheel by the previous owner and there is no mounting plate. The steering wheel has a tapered bore in the hub which fits directly on the shaft. I suspect he took the 2 spoke UK wheel together with the 11D engine for his older car but I am not sure whether his older one was French or English. It was probably English though as it was in South Africa.
