Reply To: Is this part of the carb???
Traction Owner’s Club Forums Technical Engine Is this part of the carb??? Reply To: Is this part of the carb???
#26668
Peter Fereday
    Ok Super Sleuth – it IS very slightly tapered, 4mm one end and 4.3mm at t’other. And just fits in the hole in the carb body show in the yellow box, fitting flush with top of body on its taper. And note the gasket has no hole through at this point – other yellow box, so maybe it is a blanking off plug? But why?
    IMGP5235b
    Any way, reckon you’re right. Many thanks.
    Peter
