Traction Owner’s Club Forums Technical Engine Fuel leaking from vacuum take off Reply To: Fuel leaking from vacuum take off
#27025
Alistair
    I also had a problem with a new Carb for my Light 15. The small flap that sits above the float had become dislodged and held the float down so it would not cutoff the fuel supply to the chamber. The result fuel everywhere. Once I had taken off the top of the float chamber the problem was seen and easily fixed.
    Alistair
