#27126
Norman Anderson
    Hi David, you’re right about the rich mixture. This is definitely running rich. It needs no choke at all when starting from cold. I haven’t looked at the fuel consumption yet, but it doesn’t appear to be great. I guess if it needs to be addressed, the only way will be to change the main jet?
