Reply To: Heater installation
Traction Owner’s Club Forums General discussions Heater installation Reply To: Heater installation
#27983
Jack Peppiatt
    DSCN5641
    Hi Garrett, I fitted a heater and this was my plumbing arrangement. I bought ‘T’ hose fittings to put into the flow and return from the water pump, a valve to shut off the flow to the heater which is mounted on the side pontoon and only just visible in the picture. I used a Clayton heater, still available, which has a better heat output than the original Smiths version with two doors. I found that having a variable rheostat on the fan speed was useful, the heat output can become too much. I fitted air bleeds in the smaller hoses in the cabin, but they turned out to not be necessary. If you would like more detailed photos please let me know. I got hold of a Citroen advance control lever, which I have mounted below the dash to turn the heater on and off.
    • This reply was modified 5 years, 6 months ago by Jack Peppiatt.
