![DSC_1304[5196]](https://traction-owners.co.uk/wp-content/uploads/hm_bbpui/28204/Td5ikpd89ksuxequn7wk4hh2idbahpum5.jpg)
Hello Roger
Thank you for your reply.
This is my wheel with all plastic removed, the alloy spokes are a very rough casting but with some work they could be cleaned up, I could sandblast the steel rim, what sort of paint did you use, most of the u-tube videos I’ve seen use an epoxy base color and then a clear epoxy coating for wear resistance.
Nigel
