I found this quite badly deteriorated Blumels 17″ diameter wheel on Ebay for which I gave £20. I couldn’t believe my luck when I found that it had the same size Woodruff keyed fitting on the column. It was easy to polish the alloy hub and then I used some hockey stick foam handle grip which has adhesive on the back and having cleaned the rim as best I could I wrapped the rim with the foam. I finished this off with a leather glove (comes as a kit) which I stitched on. It is soft and comfortable to use and looks good – I think.
