Reply To: Rear screen seal
Traction Owner’s Club Forums Technical Bodywork & interior Rear screen seal Reply To: Rear screen seal
#29535
    Last sentence should be ….
    The joint in the main seal on the front screen should be bottom centre.
    A spot of “superglue” at the joint is not a bad idea either – perhaps especially worth doing in your case when the joint is at the top? But be careful not to stick the rubber to the bodywork!
    B……..
