Reply To: Rear screen seal
Traction Owner’s Club › Forums › Technical › Bodywork & interior › Rear screen seal › Reply To: Rear screen seal
#29538
    David,
    It appears the description on our spares list is incorrect …… you just can’t get the staff!
    On our list TOC Spares pt. No. F4A is cross-referred to Citroën part number 802668 and that is actually the pressed steel frame which trims the inside of the rear window.
    And, now I think about it, it might be this frame (rather than the plywood) that clamps the glass to the bodywork.  Unfortunately it is a number of years since I last fitted one so I am no longer as sure as I thought I was when I penned the earlier message.  Sorry.
    I doubt you need replace the metal frame so, if not too late, suggest you cancel your order and advise CT to correct the list – but it will probably be some time before the change gets as far as the website.
    Hope this helps.
    B……
