Reply To: Valve Stem Seals
Traction Owner’s Club › Forums › Technical › Engine › Valve Stem Seals › Reply To: Valve Stem Seals
#29871
    Nigel, on the question of CV joints. Several years ago I replaced my shafts with CV joints at both ends. I have had the gaiter on the inner CV joint fail twice (same side). I don’t know why it fails, nor why the other one doesn’t. If I was doing the job again, I would probably go for shafts with just the outer CV joints and retain the inner UJ and spline arrangement because it is easier to grease that than change the gaiter.
