Hi Paul- Can you re-post the photos? There is a rubber seal that holds the glass to the metal channel that raises and lowers the window. This would have a rubber flange that sticks out at 90 degrees from the rubber channel. This will close off the area between the glass and the door itself when the winow is shut. It’s not much of a seal, water will be carried to either end of it and run down inside the door. I have seen cars with a seal that sits on top of the door and rides along the glass but that would be due to the ingenuity of the whoever installed it.
