Reply To: Petrol in tank.
Traction Owner’s Club Forums Technical Engine Petrol in tank. Reply To: Petrol in tank.
#30778
    I have no experience of petrol preserving products.  To date I have left my cars with whatever is in the tank and, so far at least, have not experienced fuel problems, even after a car has stood for several months.
    Of course the fuel pump will need to be primed after a long period of inactivity and that is where an electric pump can be a boon.  If  no electric pump is fitted, fuel can also be “encouraged” to the pump by pressurising the tank.  Simply blowing a lungfull of air into the filler is usually enough to achieve this – just remember to wash the ring from round your mouth afterwards!
    If they dry out, pump valves and the carb float may stick initially and I have also known the seal on the glass top of my pump to dry out and allow a fuel leak until it is once again impregnated – in fact the latter happened recently as the car was out of commission for some time during the very hot weather before I finally sorted out the transmission problem.
    B ….
