Petrol in tank.
Traction Owner’s Club › Forums › Technical › Engine › Petrol in tank.
  • This topic has 4 replies, 3 voices, and was last updated 4 years ago by Dave Thornley.
  • #30777
    Dave Thornley
      Having the tank half full and not envisaging doing too much more motoring this remaining part of the year due to one thing and another what should I do?
      Leave half full and put in some pertol preserver, or just leave half full.
      Drain out or fill up and use or not use preserver.
      Thanks
      #30778
        I have no experience of petrol preserving products.  To date I have left my cars with whatever is in the tank and, so far at least, have not experienced fuel problems, even after a car has stood for several months.
        Of course the fuel pump will need to be primed after a long period of inactivity and that is where an electric pump can be a boon.  If  no electric pump is fitted, fuel can also be “encouraged” to the pump by pressurising the tank.  Simply blowing a lungfull of air into the filler is usually enough to achieve this – just remember to wash the ring from round your mouth afterwards!
        If they dry out, pump valves and the carb float may stick initially and I have also known the seal on the glass top of my pump to dry out and allow a fuel leak until it is once again impregnated – in fact the latter happened recently as the car was out of commission for some time during the very hot weather before I finally sorted out the transmission problem.
        B ….
        #30779
        Dave Thornley
          I was only wondering as I am want to do at times if there was a preferred method. I know every year at the end of the season i put fuel preserver into things like my chainsaws, mowers etc and run them until they starve of fuel and have no problem in getting them up and running in spring. I was not sure if between the devuil and the deep blue sea. Full tank no air but possiblity of petrol going off and empty tank full of air with its inherent moisture.
          Will just bung a bit of fuel save in and leave her.
          #30780
            I’ve never used any kind of fuel stabiliser over the winter and have never had a problem starting in the spring. I park it, disconnect both terminals of the battery and cover it up. On startup in the spring, I do have to smack the carb with a rubber hammer as the needle valve can get stuck shut but once I do that, it’s good until the next lay-up time. I’ve never worried about the fuel level-maybe there is moisture in the tank but the first thing I do in the spring is fill it up and drive it for a couple of hours and all is well.
            #30782
            Dave Thornley
              Sounds fair method to me. I know being winter helps as fuel last longer if colder, not sure why though.
