Reply To: Brake Drum Wear Limit
Traction Owner’s Club › Forums › Technical › Brakes › Brake Drum Wear Limit › Reply To: Brake Drum Wear Limit
#35949
    For those without access to a large internal mic, the solution is to adjust a pair of ordinary internal callipers to the id of the drum and then measure that setting with a suitable external measuring device.
    However, as any necessary rectification will almost certainly entail seeking the sevices of an engineering workshop with appropriate measuring facilities, I would simply take the drum(s) there to be checked in the first place.
