Brake Drum Wear Limit
Traction Owner’s Club › Forums › Technical › Brakes › Brake Drum Wear Limit
  • #34115
    Nigel Watling
      Does anyone know what the max dimension the front brake drum can be skimmed out too please on a 1951 Light 15.
      Nigel
      #34485
        The manual, operation 120.17, states …
        Do not increase by more than 2 mm. the original drum dia. which is 255mm. (10 inch drums) or 305mm. (12 inch drums).
        #34487
          Oops …
          Correction to above – it is workshop manual operation 120.16c.
          #34791
          Nigel Watling
            Thanks Bernie, I missed this first time looking in the manual, just awaiting delivery of internal micrometer from fleabay to now check.
            Nigel
            #35947
              Following on, I would think that the dimension that matters is the remaining thickness. I wonder what thickness 255 or 305mm equates to.
              I suspect more of us have a 25mm external micrometer than have a 250mm internal one.
              #35949
                For those without access to a large internal mic, the solution is to adjust a pair of ordinary internal callipers to the id of the drum and then measure that setting with a suitable external measuring device.
                However, as any necessary rectification will almost certainly entail seeking the sevices of an engineering workshop with appropriate measuring facilities, I would simply take the drum(s) there to be checked in the first place.
