Reply To: starter motor removal 11BL
Traction Owner’s Club Forums Technical Engine starter motor removal 11BL Reply To: starter motor removal 11BL
#36953
Thierry Gest
    Hi. I did this recently on my 1952 11BL. I removed the rear engine bolts from inside the car and then using a hydraulic jack and pieces of wood under the sump, I lifted the engine very slightly. That gave enough clearance under the manifold to get the motor out.  I have now fitted a modern alternative (from wosp) which is much smaller and hopefully will be more reliable.
    Cheers
    Terry
