<p style=”text-align: left;”>A possible disadvantage of jacking under the sump is additional compression of the sump gasket which can then lead to leaks unless the sump bolts are all retightened once the load is removed.</p>
The engine stand shown in the manual is designed so that the weight is taken on the sump bolt heads and not the sump itself, for the same reason.
