Reply To: Gear lock mechanism and clutch adjustment
Traction Owner’s Club Forums Technical Gearbox & drive shafts Gear lock mechanism and clutch adjustment Reply To: Gear lock mechanism and clutch adjustment
#37459
Jakub Salata
    <p style=”text-align: left;”>If someone adjusted the clutch toggles wrong (too high) when installing one, there might not be enough space for proper throwout bearing clearance and position adjustment.</p>
    If the gear lock mechanism was removed, the 2 balls wouldn’t really cause much resistance, and might fall out of the T piece hole, and I couldn’t find one at all (though access is terrible).
    If it was disconnected and in place, the selectors wouldn’t move at all.
    Is there any Citroen model which might have a very similar gearbox but without the lock mechanism?
    Screenshot_20250905_160224_Drive
