I use a shaped wooden spacer that supports the width of the cradle to spread the load. It needs a slot along it’s length to accommodate the central seam of the cradle.
Once the front is high enough, lower the car onto axle stands close to the jacking points otherwise the geometry can cause the shafts to foul if the suspension is just left “hanging”.
B…
