Thanks Again Berni,
Yes was a bit of a wiggle but got it out, also used a bit of wood batten as a wedge to keep the window up while getting it out .
the mechanism is worn so need to source a replacement. If It’s going to take a while to get one I was thinking of using the one in the passenger door, do you know if the winder in the passenger door will work in the drivers door.
André
