Reply To: Battery cable connection to the starter
Traction Owner’s Club › Forums › Technical › Electrics › Battery cable connection to the starter › Reply To: Battery cable connection to the starter
#38355
    I assume you have a cable operated mechanical switch mounted on the starter body.
    If so, I have never seen one with such a small connector.  As you say, it is usually an 8mm thread.  I wonder if the switch has been replaced at some time with something “non-standard”.
    If you can’t easily change the stud, I would suggest replacing the switch unit.
