Traction Owner’s Club › Forums › General discussions › Ownership, JUX 775, & The Automatic Gear Box › Reply To: Ownership, JUX 775, & The Automatic Gear Box
Hi Ren
JUX775 is in the TOC database. When I first looked I couldn’t see it – maybe I was also looking for 755! It is a black 1953 Light 15 that’s been in the database since 2005. The listed owner is no longer a member of the TOC.
The cost, and therefore viability of making this a runner really depends on what is wrong with it. I can see its listing on eBay
<p style=”text-align: center;”> This vehicle has had the same owner for the last 22 years and has the original brown log book as well as it’s V5.
Registered as a historic vehicle and therefore tax free, there is a photographic history of the complete engine rebuild as well as an enormous amount of other documentation.
Chassis number 9/530964 and engine number AM 14691 will confirm that the vehicle was originally registered on the 8th August 1953
Extras: Jack, wheel brace, steering wheel, tools
MOT: not required Tax: £0
History: vast, including a detailed photographic record of the restoration 20 years ago. This vehicle was driven approximately 2 years ago but was used infrequently by its last owner’s due to medical issues.</p>
The pictures show that an alternator has been fitted, indicating that someone has been interested in the car. It looks a bit scruffy but I’ve seen a lot worse. What they don’t show is the condition of the floor / sills. I think I see a stainless exhaust. It will at least need new tires (one appears to have come off). That’s £1000 for Michelins or £750 for Blockleys. The car is listed as being in Dover. It’s quite a way from you but it may be known in the Kent – East Sussex area.
As for the automatic gearbox. You have inspired me to revisit some research I did a few years ago and put something together for F-P. As Bernie says it was only tried on the 1300 engine – although it was supposed to be tried on the 1911 engine. Alain Cerf’s book suggests that the Citroen engineers were not as keen as André Citroën and may have been a bit slow and negative in their endeavors. Worth noting is that the automatic gearbox proposed for the Traction Avant is not the one that Sensed de Lavaud designed in the ’20s and demonstrated on various larger engined vehicles. The Traction Avant scheme was a torque converter designed by SdeL coupled with a 2 speed epicyclic gearbox. There were 3 competitors for the gearbox part – Cotal electromechanical (preferred by SdeL), pure mechanical (preferred by Citroen engineers – but id it exist?), no gearbox at all (which is what appears to have been tested on the 1300 cars). The records are a bit confusing but if it is true that the tests on the 1300 car were with only a torquer converter, it is not surprising that it was not working. That kind of thing needs a big torquey engine – e.g the Buick Dynaflow.
Since the ’30s many companies have spent many $$ to develop automatics gearboxes for small engines. For the most part, excepting CVT and DSG boxes, the preferred solution is a torque converter and an epicyclic gearbox with as many gears as possible. So the original l concept was on the right path. Something could probably be made from a standard torque converter and a Cotal gearbox and squeezed into the space available. It would cost a lot of engineering hours though.
