11BL boot
  • This topic has 6 replies, 3 voices, and was last updated 5 years ago by Larry Lewis.
Viewing 7 posts - 1 through 7 (of 7 total)
  • #27998
    Andrew Middleton
      Hi All new here looking for a bit of help , thanks ,could someone send a pic of what a 11BL weather strips should look like , cheers Andy
      #27999
        Big boot or small boot?
        B……
        #28008
        Andrew Middleton
          Hi Bernie ,it is a big boot , just looking to see how the rubber seal is fitted , mine is currently missing ,i have the top strip and a new seal and clips ,would jus like to see how it is fitted properly , thanks Andy.
          #28012
            Top strip is fixed to shell with small bracket screwed at each end.
            Boot “surround” only fits to the return on the sides and bottom of the lid with the bottom corners chamferred and the top edges blended and the  clips evenly spaced
            Mine is small boot so can’t help with pictures but I am sure somebody else will now do so.
            B…..
            #28013
              Although this arrangement offers a relatively weatherproof seal, the moment you open the boot the top seal is lost and any water on the top of the boot lid is spectacularly dumped through the gap onto your contents.
              Rule 1 – always wipe excess water off before opening the boot
              Rule 2 – place a waterproof sheet over the boot contents to direct water into the rear well from where it will drain.
              B…..
              #28014
              Andrew Middleton
                Thanks Bernie , i am having to take the boot off as the hinges ar terrible and i have new ones , i have new top seal and surround seal and clips . also got new lock for boot . hopefully i can get it water tight !!! thanks again for your time , cheers Andy .
                #28017
                Larry Lewis
                  It seems to me that originally the water would drip into the flange at the top of the boot and drain away on either side. It’s sure not the best design, is it? I wonder if a wider trough attached to the upper flange would be an improvement, something made of plastic, maybe? When the warm weather returns I may come up with something like that.
