I am in the process of making a wiring loom for my 1948 Slough built Light 15. I am using the wiring diagram No W2147 as a basis for the design but it does not feature an ignition light.
The car has an ignition light installed on the dash and did work, I unfortunately did not take enough notice of the detail of the rats nest I removed especially around the aforementioned light.
I believe it goes between the “ignition on” side of the ignition switch and the D terminal of the Lucas RF95 regulator. It does not pass through the regulator.
Are my assumptions correct
