Different slips out of gear
Traction Owner’s Club › Forums › Technical › Gearbox & drive shafts › Different slips out of gear
  • This topic has 7 replies, 4 voices, and was last updated 2 years ago by Tim Walker.
  • #36251
    Tim Walker
      My 53 11L doesn’t lock in gear until the clutch is completely in. I can’t remember what to do, (if I ever knew!)  Can someone help, and yes, I’ve all the books, but the clutch adjustment escapes me….
      #36253
      Tim Walker
        I meant, completely out…..d’oh!
        #36257
          traction clutch interlock
          Hi Tim
          It sounds like you need to adjust the position of the bracket that is moved by the clutch release bearing and pulls on the interlock rod.
          You need to set the gap “b” shown in the diagram. The words in the manual say this
          “Depress clutch pedal to bring toggles JUST INTO CONTACTWITH THRUST RACE. Adjust gear lock withdrawal fork on bracket of thrust race in order to obtain a clearance ‘b’ *of 1 to 2 mm. between head of plunger and face of fork (see Drawing 6).”
          But essentially you are making the clutch pull the interlock rod further than it does now.
          Tony Buxton
            Crude but visual…
            Good luck
            #36261
              that’s a very helpful video
              Thanks
              Tony Buxton
                Perhaps the gear selector linkage rods need to be checked to see if the gears are filly engaged before the lock is activated.
                Good luck,  T
                #36265
                  If it has been jumping out of gear a lot, or for a long time, there could well be damage to the two selector rods in the gearbox lid.  The recesses designed to accept the détente mechanism become worn which can prevent positive location and lead to gears not being correctly selected.
                  #36577
                  Tim Walker
                    That’s extremely helpful, and now I’ve got it!
                    Tim
