Distributor Question
Traction Owner’s Club › Forums › Technical › Engine › Distributor Question
  • This topic has 1 reply, 2 voices, and was last updated 2 weeks ago by Bernie.
  • #38957
    David Horsley
      Why do some cars with a manually controlled advance and retard have a spring linking the distributor to a lug on the dipstick housing whilst other cars with similarly controlled distributors don’t ?
      What does this spring do ?
      Does it matter if it’s missing ?
      I have the location points for a spring on my 1951 11BL but no spring – it seems to start and run OK without it !
      #38959
        The spring is to overcome any “stiction” and ensure the distributor returns when the lever is retarded.
        If the control is via a solid wire it will push back but if a bowden cable is fitted, the braided inner cable is less likely to have the necessary rigidity to push the distributor clockwise.
        • This reply was modified 2 weeks ago by Bernie.
