Hi, I’ve recently bought a Slough build Light 15, but the brakes require some attention. The front flexible hoses are not secured. I’ve seen examples where there is a plate mounted off what I’m going to call the front suspension mount (as shown on a French car) . This is missing on mine, (the plate not the suspension). There is also a clip like bracket welded to the body, could this be where the hose is fixed to?
The first photo shows a normal hose mount. The second looks like a bodge. The hose should go from that mount bracket directly to the wheel cylinder. It can’t be too hard to find the bracket or have one made.
This reply was modified 2 months, 2 weeks ago by Larry Lewis.
I could do with knowing the width, thickness of the plate as well as the distance between centres so I can make some. If anyone has easy access I’d be greatful.
